Looking for Velcro backed roll of sandpaper http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=47688 |
Author: | BradHall [ Tue Apr 26, 2016 6:27 pm ] |
Post subject: | Looking for Velcro backed roll of sandpaper |
I've finished building a thickness sander and have a problem. I ordered a roll of 2" self adhesive 80 grit Paper as recommended by a couple of forum members. The adhesion has failed several times. The flapping will definitely get your attention. I made the discs from HDF and sealed the entire roller with a fast drying clear acrylic sealer from a spray can. I let it dry for several hours. No joy. I do recall someone using a Velcro set up, but can't locate it with Google. Can anyone steer me to the supplier? Thanks. |
Author: | Bri [ Tue Apr 26, 2016 7:16 pm ] |
Post subject: | Re: Looking for Velcro backed roll of sandpaper |
https://www.woodworkingshop.com/search. ... loop+rolls Try this or search for "hook and loop" You might also consider having some type of clip to hold the ends of the paper below the surface of the drum. This way you could use regular rolls.( non psa or velcro) |
Author: | Alain Lambert [ Tue Apr 26, 2016 9:25 pm ] |
Here is how I hold my sandpaper strip |
Author: | BradHall [ Tue Apr 26, 2016 10:32 pm ] |
Thanks guys. |
Author: | kencierp [ Wed Apr 27, 2016 6:15 am ] |
We have tried all types of abrasive on our drum sanders and without question Zirconia (80g) works the best and more importantly lasts three or four times longer. I recommend taking the time to design your sander to use standard abrasives if for no other reason to take the advantage of the Zirconia, seem the choices with HL are very limited and expensive. Good suggestion above for the mechanical fasteners, there are others on line. http://www.woodworkingshop.com/product/pe68080/ |
Author: | WudWerkr [ Wed Apr 27, 2016 12:44 pm ] |
i use 1/2" strip of duct tape and go around drum at both ends . requires knowing where NOT to run board through . |
Author: | kencierp [ Wed Apr 27, 2016 1:13 pm ] |
Quote: i use 1/2" strip of duct tape and go around drum at both ends . requires knowing where NOT to run board through Actually I used 1" filament reinforced packaging tape on a shop made unit many years ago -- I got the idea from Grizzly since this was how it was held in place on one of their models. Maybe still is? |
Author: | Glen H [ Wed Apr 27, 2016 4:01 pm ] |
WudWerkr wrote: i use 1/2" strip of duct tape and go around drum at both ends . requires knowing where NOT to run board through . Same here but I get away with the Stew Mac binding tape. Has never let go and easy to pull off. |
Author: | surveyor [ Fri Apr 29, 2016 9:00 am ] |
I use the velcro backed sand paper (hook & loop) and got from "onlineindustrial" supply. Come to think of it, you could probably just run a band of masking tape around the drum in several places then coat with superglue and roll your sandpaper around that. Then the only thing stuck to the drum is the masking tape. |
Author: | jayluthier [ Sat Apr 30, 2016 5:05 pm ] |
Grizzled sells a kit to convert a drum sander to hook & loop. I used it to successfully convert my 16" drum sander. I strongly recommend it. To Sent from my iPhone using Tapatalk |
Grizzley, that is. Sent from my iPhone using Tapatalk |
Author: | bobgramann [ Sat Apr 30, 2016 7:49 pm ] |
Also, supergrit.com |
